585,927 active members*
3,876 visitors online*
Thread: XML files
    Aug 2009
    20
    XML files
    When I go to start up mach 3, I go to mach 3 loader, then select the XML file for the DMM breakout board I'm using, and mach 3 then loads up.
    I'm using an ESS and 2 DMM breakout boards
    I'm adding a c10 board to another port on the ESS. The c10 board has an xml file for it. Its been awhile since I set up mach 3. My question is where do I put the xml file for the c10 board? A certain folder?
    Re: XML files
    You can't use multiple .xml files. If you're adding the C10 to your existing system, you'll need to manually enter the port and pins.
    .xml files go in the Mach3\ folder
    Aug 2009
    20
    Re: XML files
    oh so basically if I plug c10 board into the ESS port 3, I just have to enter port 3, pin # for whatever I'm connecting to the board? I didn't realize xml files just make it so you don't have to manually input the ports and pins.
    Thanks for the info
    Re: XML files
    Basically, yes.
    The .xml file contains all of your Mach3 settings. So if you switch to a new .xml for the C10, then you lose all the previous settings for your current setup.
  1. Converting Illustrator files to Gcode files
    By acoop101 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2023, 11:13 PM
  2. RFQ: Convert SolidWorks files to MDD files for Hanwha XE20
    By THPP in forum RFQ (Request for Quote)
    Last Post: 02-23-2017, 02:08 AM
  3. Replies: 2
    Last Post: 01-16-2016, 03:23 AM
  4. Replies: 10
    Last Post: 04-12-2014, 04:03 PM
  5. converting CT Scans [ dicom files] to cutting files
    By fiddlemakermike in forum WoodWorking Topics
    Last Post: 05-09-2013, 02:15 AM
