585,978 active members*
4,360 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Kflop + Kanalog + Mach 3 can it work with alterelettronicadrive DCD01 ?
Results 1 to 10 of 10
    Mar 2005
    137
    Question Kflop + Kanalog + Mach 3 can it work with alterelettronicadrive DCD01 ?
    Hi guys,
    we have an Kflop+kanalog
    could it work to control and DCD01 drive
    https://www.alterelettronica.it/en/products/dcd1/
    I'm looking at the pdf it shows +10V and -10V to control
    however it doesn't say if it's A.C. or D.C. current i know the drive is for DC servo motor but the control doesn't tell me what kind of current i have to input there.
    Kanalog will give me +10VAC and -10VAC
    what do you guys think ?
    thank you for your advise
    Attached Files Attached Files
    May 2006
    4045
    Re: Kflop + Kanalog + Mach 3 can it work with alterelettronicadrive DCD01 ?
    Hi k-linkz,
    This figure from the manual clearly shows how a potentiometer and some switches can be used to create a +/-10V DC command signal to control the motor current/torque.
    Attachment 435280
    We often recommend this simple test with a 1.5VDC battery.
    TK
    http://dynomotion.com
    Mar 2005
    137
    Thanks for the reply,
    How am I suppose to control this all the breakout board I see use step/dir to control the drive .
    Can you point me to a breakout board that does +-10v DC
    Sent from my moto g(6) play using Tapatalk
    May 2006
    4045
    Hi k-linkz,
    KFLOP + Kanalog does +/- 10V DC.
    You would also need differential encoder feedback.
    And the time and patience to do servo tuning.
    We don't recommend using Mach3 as it is obsolete, unsupported, and has relatively poor trajectory planning. Consider our free KMotionCNC instead.
    HTH
    TK
    Mar 2005
    137
    Hi Tom,
    I'm looking at the schematic of the kanalog i'm unsure where is the +/-10V DC
    I see a +/- 10V but it says analog which correct me if i'm wrong but analog is AC not DC. or is it via the OPT 80V ?Attachment 435314
    May 2006
    4045
    Hi k-linkz,
    The Drives need a DC command and the Kanalog DACs output a DC signal. Like I previously suggested you can test/verify this with a 1.5V DC battery. Of course in operation the voltage would vary and be positve and negative depending on what amount and direction of torque is currently needed.
    The opto outputs are for tuning things on and off like coolant pump relays and such.
    TK
    Mar 2005
    137
    Hi Tom,
    I've tested the drives with a battery, they moves the motors. so that is ok. So basically i should plug the output +/- 10V to drive even it says Analog it will give me DC. and then plugin the encoder output to the right channels to the board and start the config and setup procedure.
    Cool i'll give it a try
    thanks Tom
    May 2006
    4045
    Hi k-linkz,
    Did reversing the battery reverse the motor torque?
    Its not clear what you mean by this. DC is an analog voltage. But yes that sounds correct.
    TK
    Jul 2006
    5
    Hi, I have problem with output pins... I configure outputs with port #2 and pins #14* to 15* , and not have any signal..
    I use kflop + Kanalog with Mach3....
    Enviado desde mi HUAWEI VNS-L23 mediante Tapatalk
    May 2006
    4045
    Hi redx,
    Please don't run Mach3 until after you have your axes configured, working, and tested in KMotion. When using KFLOP, it controls the configuration and generates the motion not Mach3.
    What kind of Drives do you have? How are they connected?
    TK
  1. Would like to know if KFLOP and Kanalog boards will work with my Upgrade
    By want-to-be-cnc in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-26-2016, 04:47 AM
  2. KFLOP/Kanalog set up
    By cjsamples in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-30-2015, 12:58 AM
  3. KFlop Kanalog and DMM
    By slonold in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-26-2014, 10:54 PM
  4. Need help setting up KFlop and KAnalog with Analog Servo Drives and Mach 3
    By MetalStorm in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-26-2014, 04:29 PM
  5. New CNC Router Project, Using Kflop, KANALOG, KMotion and Mach 3
    By Rickstar in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-04-2012, 06:26 AM
