585,727 active members*
4,078 visitors online*
    Apr 2015
    10
    Cool What 4 Pin Connectors and Cables do you use?
    I am gonna redo my controller box soon here. I was wondering what 4-pin Connectors/Plugs people use for their steppers. Somthing that you can build a cable out or better yet buy and somthing that also has a flange plug. So male/female connector and a flange plug. Preferably solderless crimp style?
    Aug 2008
    213
    Re: What 4 Pin Connectors and Cables do you use?
    Quote Originally Posted by Elocremarc View Post
    This is what I used on my enclosure.
    Link for these Connectors
    Attachment 436236
    15362
    If you want a reliable system you will not use any Plugs direct wire is the best way to do new installs and is less work, just where you enter the cabinet you use cable glands which also can be used for shield cable Grounding
    Mactec54
  1. Replies: 11
    Last Post: 04-03-2018, 12:56 AM
  2. What Cables and Connectors
    By rpovey in forum Benchtop Machines
    Last Post: 07-27-2011, 09:11 AM
  3. Need connectors for motor cables
    By jharvey407 in forum Controller & Computer Solutions
    Last Post: 06-12-2011, 08:25 PM
  4. Connectors
    By LaserImage in forum CNC Machine Related Electronics
    Last Post: 07-10-2008, 06:53 PM
  5. DB-25 Connectors
    By Nmbmxer in forum CNC Machine Related Electronics
    Last Post: 10-17-2005, 01:05 AM
