585,974 active members*
4,338 visitors online*
    Mar 2016
    68
    G52 offsets not shown in mach3 screen
    Hi! I’m still learning gcode and cnc and I’m using Mach3 wizards for my small jobs.
    I’m doing a series of grooves in a part, and I edited a wizard generated code, aleays in the same X dimensions, but I change only the z value for each groove. So I use G52 to each offset and I copy and paste always the same code for each groove, only change the g52 value for Z.
    It works normally, but in the mach3 screen, only one groove is drawn, not the series of grooves, side by side. As all grooves were made over each other. Is there a way to fix it so all my grooves are shown on the screen?
    Re: G52 offsets not shown in mach3 screen
    No, it's a bug in Mach3.
    Jun 2010
    4256
    +1 to Gerry.
    It is annoying of course, but the actual cutter path is OK.
    Cheers
    Roger
    Same thing happens with work offsets, if I recall correctly.
  1. mach3 screen
    By CAD226B in forum Shopmaster/Shoptask
    Last Post: 09-14-2017, 10:39 PM
  2. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  3. Mach3 tool length offsets
    By Dstamp in forum BobCad-Cam
    Last Post: 07-15-2013, 12:01 AM
  4. Weird display in Mach3 with uses of Offsets G57 & G58
    By mikefalkner in forum Mach Software (ArtSoft software)
    Last Post: 06-16-2013, 08:17 PM
  5. How to make block numbers to be shown on the screen?
    By dmitriy in forum Uncategorised MetalWorking Machines
    Last Post: 07-16-2011, 10:24 AM
