585,973 active members*
4,165 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > C-Axis TPA / HOME Failure (Cincinnati Arrow 2 - Siemens servo drivers Acramatic 2100)
    Jul 2005
    107
    Hello.
    Please some help with a Cincinnati Arrow 2 - Siemens Servo drivers - Acramatic 2100.
    The problem is when the machine is homing. The spindle rotates 6 times and it can not get the home position.
    The message is: C-Axis TPA / HOME Failure.
    The machines was working ok.
    Mar 2011
    463
    Re: C-Axis TPA / HOME Failure (Cincinnati Arrow 2 - Siemens servo drivers Acramatic 2
    There are a number of things that can cause this.
    First, the alignment is done based on a signal from the spindle motor encoder (or resolver depending on vintage) so there could easily be an issue with the encoder/resolver, drive/drive controller card, or cable (since the cable flexes in the cable track, they can fail over time).
    Depending on the spindle option, it may also have a prox switch mounted at the spindle to confirm orientation. If this switch fails (or the cable to it), the machine will not be able to align.
    Jul 2005
    107
    Quote Originally Posted by maver1ck View Post
    The proximity switch is broke. I'm going to replace it. Hope this solve the problem.
    Jul 2005
    107
    The proximity sensor was broke, because one spring washer was broke in half and one part slide out a little bit, like an ax it cut the proximity sensor.
  1. Arrow 500 Acramatic 2100 X AXIS TPA/HOME FAILURE
    By AGEMACHINERY in forum Cincinnati CNC
    Last Post: 12-05-2019, 08:47 PM
  2. cincinnati arrow 1000 acramatic 2100 batteries
    By dbills in forum Cincinnati CNC
    Last Post: 10-24-2017, 08:32 PM
  3. Post for Cincinnati Arrow 750 , controller Siemens Acramatic 2100
    By bacio70 in forum Uncategorised CAM Discussion
    Last Post: 08-23-2017, 09:14 AM
  4. Cincinnati Arrow 750 with Acramatic 2100...
    By Trigg in forum Cincinnati CNC
    Last Post: 04-29-2015, 10:18 PM
  5. Cincinnati Arrow 2000 Siemens Acramatic 2100
    By skeetskurt in forum Cincinnati CNC
    Last Post: 02-24-2013, 04:07 AM
