CNCRP / Avid CNC NEMA23 Control Electronics CRP800 with Ethernet Smoothstepper. This was used for about 200 hours, and then fully rebuilt and tested by Avid. It's been in the box since they sent it back (I ended up with two). It is the enclosure that comes with this system: Plug and Play NEMA 23 CNC Control System - CRP800-00E-5 | Avid CNC . The motors and cables that come with that kit are not included but are available here: NEMA 23 CNC Electronics | Avid CNC
Asking $800 plus shipping or local pickup in Chicago.
- Industrial steel NEMA Enclosure with mounting hardware
- Ethernet Smoothstepper
- (4) All digital CRP5056 drivers, pre-wired to power terminals, motor plugs, and logic board, with support for an optional 5th motor driver.
- IO breakout featuring a dedicated spindle relay and (2) 30A general purpose AC relays, (8) 12V powered M12 ports for homing/proximity sensors (or general input signals) (proximity switches sold separately), and on-board 0-10V analog output for spindle speed control.
- 600W 48V regulated power supply with plenty of power for 4 motors (an additional power supply is provided for the optional 5th motor driver configuration)
- High quality 5V and 12V regulated power supplies for logic and sensor power.
- (4) 5A rated plug and play motor terminals.
- Plug-in E-Stop unit.
