585,700 active members*
4,336 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > US split phase 220V power supply question
    Nov 2013
    30
    I live in North America and use split-phase 220V where I can in my shop. I am looking to source a 24VDC power supply, and managed to get myself confused. Most of the DIN mountable power supplies I see that claim 110V/220V compatibility are single phase devices (labeled L and N), such as https://www.mouser.com/datasheet/2/2...ec-1109663.pdf. I assume I can't (or shouldn't) plug my 220V (both hot wires) into that right?I guess I can stick with a 110V PS, but was trying to simplify my setup since I need 220V for my VFD.
    Speaking of my 220V VFD (Haunyang HY01D523B). I assume I am ok using my split-phase power into that. I would just connect both hots into the R and S terminals, and leave T unconnected.
    Dec 2013
    5717
    Re: US split phase 220V power supply question
    In N.A. the voltage is really 240V/120V or sometimes called 230V/115V, just depends on the label on the device. Many times your actual line voltage could be as high as 245V or so, it's all the same and works fine.
    For the 24VDC power supply, if you choose to wire it at 240V just connect one hot to each of the power in terminals. They may be labeled L and N, just make sure the PS is rated for 240V (220) input voltage.
    Yes, for the HY VFD, just connect the 2 hots per the manual.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2013
    30
    Thanks for the info Jim! Good to know it would work.
  1. Bridgeport R2E3 delima, 220v VFD 3 phase Versus 220V Single Phase
    By ronderkis in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2015, 04:01 AM
  2. Replies: 2
    Last Post: 06-20-2014, 05:24 AM
  3. Wiring KL-5020 power supply for 220V
    By flagger in forum Maintenance DIY Discussion
    Last Post: 06-30-2012, 06:54 AM
  4. 3 Phase AC Power Supply/Controller Question
    By jigidyjensen in forum CNC Machine Related Electronics
    Last Post: 07-15-2011, 03:12 AM
