585,885 active members*
6,067 visitors online*
    Nov 2019
    12
    I'm looking for edge/corner finder script for Chinese controller
    Hi Everybody,
    I'm looking for edge/corner finder (but I would be over the Moon with a center finder) macro/script for my Chinese engraving machine. Of course, its controller is Chinese as well (BL-USBMach3).
    I have tried macros from youtube videos unfortunately, they didn't work.
    I have bought Gerry 2010 screenset, it didn't work even with his Chinese macros.
    However, the existing HiddenScript.m1s for the auto tool height works perfectly, see here and attached as well.
    'chengdu xhc tec. probe z surface macro
    FeedCurrent = GetOemDRO(818) 'Get the current settings, OEM DROs (818)=Feedrate DRO
    ZCurrent = GetOemDro(802) 'OEM DROs (802)=Z DRO
    GageH = GetOEMDRO(1001) 'OEMDRO(1001)=Gage Block Height
    ZNew = ZCurrent - 300 'probe down 20 mm
    Code "G90F200" 'slow feed rate to 100 MM/MIN
    SetOemDRO(818,200)
    Rem Code "G4 P1" 'Pause 1 second to give time to position probe plate
    Code "G31 Z" &ZNew
    While IsMoving()
    Sleep(10)
    Wend
    Call SetDro (2,GageH) 'DRO(2)=Z DRO
    FinalMove = GageH + 10
    Code "G0 Z" &FinalMove
    Code "F" &FeedCurrent 'restore starting feed rate
    SetOemDRO(818,FeedCurrent)
    Could someone help me please to modify this script or write a new based on this for the edge/corner/center finding?
    Thank you in advance,
    Kind Regards,
    Robert
    Attached Files Attached Files
    Sep 2005
    1740
    Re: I'm looking for edge/corner finder script for Chinese controller
    Robert is your control software Mach3 or Mach4? Otherwise this is in the wrong forum.
    Nov 2019
    12
    Hi wmgeorge,
    Sorry, I have forgotten to mention, my control software is Mach3 of course.
    Aug 2007
    18
    Quote Originally Posted by B77 View Post
    Hi wmgeorge,
    I think you have found the hard way that most of the cheap chinese controllers simply will NOT do a G31 probe command in X and Y axes properly, the only thing they properly put in the firmware is G31 in Z for tool touchoff.
    No amount of macro scripting will make them work for doing edge touchoff, the problem is the controller itself.
    regards,
    Eric
