585,744 active members*
5,198 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > tangent the vertical cutting tool before reaching the second path
    I am writing regarding a question about a vertical cutting tool which is used to cut glass shields and the G-Code required for specific task. We have a cutting tool in order to cut glass shields into pieces and we want it to follow a path. It cuts a line and then elevates and move to another point and follow the new path. What command I can use to make the tool tangent to the new path when the tool is in the air and is moving toward the starting point of the second path.
    Nov 2012
    1267
    Re: tangent the vertical cutting tool before reaching the second path
    Does your machine have a separate axis that rotates the tool? In that case you can probably can control it like a regular rotating axis, such as "G0 C180.0".
    Yes, but in the settings of our CNC the third axis is defined as the tangent of the path and the defined G-Code is a function of x and y only. Now it works fine but it tangent the tool on the glass shield. We aim to do so while the tool is elevated from the sample and is moving towards the target point.
    Except this method you mentioned, could we the same x, y and tangent to achieve this aim or we need to define a third axis.
    Nov 2012
    1267
    So the controller automatically orients the C axis based on the X/Y movements? What happens if you raise the tool and make a lead-in move before lowering the tool again?
    Jun 2015
    4154
    hy use interpolated rapid + radius compensation, or feed it directly at required position
  1. Problems with cutting the entire tool path(?)
    By HiFlyer4 in forum PhotoVCarve and VCarve Pro
    Last Post: 11-06-2017, 07:52 PM
  2. Advanced 3D Tool Path Cutting Options
    By aldepoalo in forum BobCad-Cam
    Last Post: 03-18-2014, 12:48 AM
  3. Engraving path so tool is tangent to surface.
    By BanduraMaker in forum Visual Mill
    Last Post: 11-08-2012, 06:45 PM
  4. Replies: 10
    Last Post: 09-05-2012, 03:30 AM
  5. Reaching a point with radiused tool on mill.
    By Kiwi in forum G-Code Programing
    Last Post: 10-02-2006, 03:33 AM
