585,763 active members*
4,002 visitors online*
IndustryArena Forum > CAM Software > MadCAM > New Updates to madCAM
    Oct 2009
    96
    Does anyone know how to implement the following new updates to madCAM in the Post Processor.
    I use Mach4.
    There are no new post processors in the update.
    I am mainly interested in G93.
    R
    egards,
    Mauri.
    • Two new variables for the post processor. "cutter_tool_list" and "machining_time". It is possible to get all cutters that are used and the total machining time listed in the output file. (3X,4X,5X and 5Xtra)
    • Post processor support for inverse time feed (G93). (3X,4X,5X and 5Xtra)
    Feb 2006
    183
    Re: New Updates to madCAM
    Mauri,
    The inverse time feed can be used as below.
    *TOOLPATH_OUTPUT*
    TRANSFORM
    *TOOL_LENGTH_OFFSET*
    NO
    *INVERSE_TIME_FEED_MAX*
    1000000
    *INVERSE_TIME_FEED_ON*
    G93
    *INVERSE_TIME_FEED_OFF*
    G94
    For example, It can be used in the tool change and tool stop sections as below.
    *TOOL_CHANGE*
    ("toolname")
    M6 T"toolnr"
    M03 S"speed"
    G00"inverse_time_feed_on""x""y""azero"
    G01"zhome"
    *END_SECTION*
    *TOOL_STOP*
    G00"inverse_time_feed_off""zhome"
    M5 M9
    *END_SECTION*
    /Joakim
    Oct 2009
    96
    Joakim,
    I just cannot figure this out.
    I tried a number of combinations but it does not change F Speed for the A Axis to equal a G93 surface speed.
    Above is a sample of my sample Post Processor for my Router Table.
    I sent you an email with more data and my Test Sample as it was too big to load here.
    PLEASE correct my errors so I can make it work.
    Thank you.
    Regards,
    Mauri
    Oct 2009
    96
    This has been fixed with the new updates.
    Regards,
    Mauri.
  1. Updates
    By Gregore in forum MadCAM
    Last Post: 03-18-2014, 05:42 AM
  2. Updates???
    By jrmach in forum BobCad-Cam
    Last Post: 09-13-2012, 06:41 PM
  3. madcam updates
    By Sky Blue in forum MadCAM
    Last Post: 12-11-2009, 09:11 PM
  4. X4 updates????
    By WingNutz in forum Mastercam
    Last Post: 10-27-2009, 06:52 PM
  5. Updates on v4
    By robinsoncr in forum MadCAM
    Last Post: 03-03-2007, 06:04 PM
