0 active members*
4,653 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > sys 103.5 software files
Results 1 to 18 of 18
    hi
    Is there anyone who has the sys 103.5 eproms files for upgrade?
    6 eproms ic (m27c512) on 1610 board
    thx
    Apr 2014
    345
    Re: sys 103.5 software files
    Can you update the software on existing chips?
    Quote Originally Posted by ianagos View Post
    yes
    with uv eprom eraser clean eproms then programmed with ic programmer
    or use 6 new blank eprom for upgrade
    but i need firmware 103.5 files
    Apr 2014
    345
    Do you know the type of eprom they use? I have hundreds of these types of chips. I got for free. I just never really knew how to identify and program them.
    Also i think I have software 102.x if you are interested and could copy it from existing EPROMs.
    if you have eprom program (sys 102.1)or sys 103.5 please send files
    eproms programmed with programmer
    ic type m27c512
    thx
    sys 101.4 eproms file
    Attached Files Attached Files
    Oct 2014
    10
    Quote Originally Posted by Mhook View Post
    I see you have the BIN files numbered. Which eprom is is 1 and so on?
    Oct 2014
    10
    Feb 2021
    does anyone have sys 103.5 version of the 88HS firmware?
    please share files!
    my 1610 board chips erased!
    Quote Originally Posted by edifadal View Post
    please share files!
    can you find it?
    Oct 2008
    1632
    If you had your PM's turned on you might have better luck.
    Quote Originally Posted by rwskinner View Post
    thx
    I have not found his file yet!
    Apr 2014
    345
    I mean I have the system 103.5 in my machine if you have a reader I can borrow.
    hi
    thx for reply
    but i need software files sys 103.5
    Oct 2008
    1632
    I only had the 101.3. I thought I had 103.5 but didn't.
    thx
    i upload 101.4 software , already.
    hi
    thx
  1. Need software advice...What software can import .JPG files?
    By pairofjacks in forum Uncategorised CAM Discussion
    Last Post: 06-01-2011, 12:18 PM
  2. Cam software output files
    By dprescott in forum Uncategorised CAM Discussion
    Last Post: 04-07-2011, 10:02 PM
  3. Software that exports dxf files?
    By Danny B in forum Uncategorised CAD Discussion
    Last Post: 03-28-2011, 03:28 PM
  4. Grid, files, other software
    By james45667 in forum BobCad-Cam
    Last Post: 02-22-2011, 08:03 AM
  5. Which software to trim .stl files?
    By Faber.sum in forum Uncategorised CAD Discussion
    Last Post: 06-12-2008, 06:42 PM
