hi all ,I have a Fadal 4020 I installed A tool setter probe ts27, and a setup probe mp8 with a mI12 Interface.. I have a Mi8-4 For the ts 27.
Problem is when I try to use the setup mp8 it says that the probe is touching when it is not. movement is inhibited like it should be but, the probe is not touching anything! When I move the probe stylus with my hands to simulate a touch the screen says probe not touching and you can jog the machine. If you let the probe stylus go the machine will inhibit movement.
I have disconnected the tool setter and hooked the mi12 outputs right to the probe input on the J12 connector and same results. The ts27 works as it should. Anybody with ideas? I'm stumped and dumb. Thank you
