585,962 active members*
3,640 visitors online*
    Oct 2009
    59
    Lines on Part
    Hello all,
    I am trying to machine a half cylinder but as you can see in pictures the result is not smooth, there some lines on the part (marble), I tried various toolpaths and using 4.5 mm of endmill.
    Any ideas please?
    1224
    Re: Lines on Part
    Try changing the cut direction so that it goes across the job.
    Dec 2008
    3109
    Re: Lines on Part
    try using surfacing strategy..."Flowline" allows to define a cusp height, even better if you also use a bull or ball mill... I suggest a bull ie 5mm cutter with R2 corners.
    ballnose cutters are not running at correct speeds when cutting at the tooltip ( zero diameter )
    surface contour will always give steps...
    plus.... do not rely on backplot or simulation to show actual finished part... it is so dependant on PC specs & screen scale it not funny. A lot comes down to trial & error ( read this as experience )
  1. Vertical lines in finished part
    By popspipes in forum Tormach Personal CNC Mill
    Last Post: 02-23-2017, 05:25 AM
  2. Replies: 9
    Last Post: 01-11-2014, 11:04 PM
  3. Replies: 2
    Last Post: 08-26-2013, 07:37 AM
  4. Dashed Lines?? Sames lines to still show dashed in different scaled viewports?
    By coykiesaol in forum Uncategorised CAD Discussion
    Last Post: 12-29-2010, 04:38 PM
  5. Replies: 1
    Last Post: 08-11-2010, 01:59 PM
