585,715 active members*
3,870 visitors online*
    Program getting stuck on m3
    Hey everyone, hope you are all doing great.
    I’m having an issue where I will run a program and it will run fine for maybe 1 run, maybe 20 runs. Sooner or later it will get stuck on line 3 and never do anything. If I stop the program and reload it, it won’t work. The only way to get it working again is to reload Mach 3.
    I’m calling the gcode that bobcad gives me a “program”.
    If it gets stuck on line 3, the status will usually say which end mill I’m using. If I just hit start run again like I would if I changed tools, nothing happens.
    I’m not really sure what’s going on. Any help or advice is greatly appreciated.
    Nov 2013
    4360
    Re: Program getting stuck on m3
    try putting the macro M03 on a separate line.
    Craig
  1. Program getting stuck sometimes?
    By 4iSteven in forum BobCad-Cam
    Last Post: 02-02-2020, 06:00 PM
  2. Stuck again ;)
    By davek0974 in forum Autodesk CAM
    Last Post: 02-11-2018, 04:32 AM
  3. program of tab program in mori sv 400 and program tool chance
    By hmtam1311 in forum Mori Seiki Mills
    Last Post: 12-10-2017, 02:54 PM
  4. TNC 310 program gets stuck after spindle start
    By danielhermle in forum HEIDENHAIN -> TNC
    Last Post: 10-02-2011, 01:14 PM
