584,866 active members*
5,090 visitors online*
Results 1 to 9 of 9
    Feb 2020
    5
    RFQ Motorcycle Axle Bushing Needed
    I need 2 axle bushings made.It's a bushing to convert a Suzuki DR650 axle and make it compatible with Suzuki RMZ 450 shocks. I believe it should be made out of Stainless 304 or 316 but would rely on your recommendation. Please see drawing. Measurements are standard inch except for the inner threads which are 16x1.5mm internal threads.
    Re: RFQ Motorcycle Axle Bushing Needed
    Hi Stickr?
    Can you give me your email or contact me? We can finish the work quickly. and price is my advantage
    [email protected]/www.plusminusthree.com
    Over 30 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding www.plusminusthree.com Email:[email protected]
    Feb 2020
    5
    Quote Originally Posted by konwey View Post
    Hi Stickr?
    Email sent
    Oct 2009
    23
    Smile Re: RFQ Motorcycle Axle Bushing Needed
    Quote Originally Posted by stickr View Post
    yes Sir, could you post a contact email or open your inbox option? Also what is the OD?
    Thank you,
    Feb 2020
    5
    Quote Originally Posted by Wrath Machine View Post
    Thank you,
    The larger outer diameter is 1.180” and the smaller outer diameter is 0.980” and I’ll see how to open my inbox option right now. One second.
    Feb 2020
    5
    Thank you,
    Okay I turned on PMs. Thank you for the heads up. Sent you a PM.
    Jan 2008
    449
    You probably should list your location, somebody could be right in your backyard. You probably want to pick 316 for the increased corrosion resistance over 304.
    Feb 2020
    5
    Quote Originally Posted by Dualkit View Post
    Thank you for the suggestion. Location for this job is Manassas, Virginia.
    Feb 2020
    Hi stickr!
    We can manufacture this type of cnc turning job with 10 micron accuracy and 0.4 ra value surface finish.
    You can visit our website for Credex Imagineering LLP | CNC Machining Component Service for more our cnc products.
    Best regards,
    Dhaval B. Goti
  1. Axle Bushing Needed
    By tee2 in forum North America RFQ's
    Last Post: 03-01-2024, 09:42 PM
  2. MOTORCYCLE AXLE SPIKES
    By BALL_D in forum North America RFQ's
    Last Post: 08-29-2016, 11:37 PM
  3. Two bushing adapters needed.
    By topduck in forum North America RFQ's
    Last Post: 09-27-2015, 02:19 AM
  4. Replies: 8
    Last Post: 08-21-2015, 07:43 AM
  5. Is it possible to turn closed round bushing into C shaped bushing ?
    By vroemm in forum Linear and Rotary Motion
    Last Post: 06-27-2006, 11:04 PM
