The machine setup:
Laser DLT300
Ruida RDC 6332G
Autofocus LFS-PM-T43 AP02
Bed 1500/3000
It is new from a china suplier.
We want to cut metal using O2.
All ok for non metal cutting, the laser is ok, manual focus then does the job ok.
But for metal cutting have to use the LFS focus. Here is a problem.
The steps I made:
Machine and accessories started
Done the calibration with the LFS, the curve is ok, the head makes the right moves.
Then Follow OFF to Follow ON. ( on the LFS panel )
And when I push the Start button on the ruida panel, the machine makes 3 beeps and on the ruida screen appears "Machine protected, worked paused".
Also if I don't activate Follow ON, so if leave Follow OFF, and hit Start, it starts the job and it works. But the head doesn't fall next to the metal sheet. It stays up.
Excuse my lot of words but hope makes sense.
So the problem is when hit Follow ON from Follow OFF.
Please any suggestions, I appreciate.
Thank you!
