585,761 active members*
4,154 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Precision Mathews PM-932 CNC Milling Machine
    Jun 2018
    84
    I'm selling my PM-932 CNC mill so I can move up to a industrial level machine. If you are looking for a turn key CNC mill loaded with options this is the one for you.
    Precision Mathews PM-932 milling machine purchased new
    Column stiffening mods
    WJ200 Hitachi VFD with 2HP Marathon Black Max Inverter Duty Motor
    Two speed belt drive spindle conversion with angular contact bearings (8500 RPM max speed)
    PMDX-126 breakout board, PMDX-107 spindle control board, Warp9 ethernet smooth stepper
    Nema 34 stepper motor with dual shafts on X and Y axis, 1600 oz-in holding torque
    Nema 42 stepper motor with single shaft on Z axis, 4200 oz-in holding torque
    DQ860MA/7.8A stepper drivers on X and Y axis
    DQ2272/8.0A peak current, 7.0A rated current stepper driver/power supply on Z axis
    350W, 60VDC, 5.9A power supply for X and Y axis
    Rollaway with AC power system components located in bottom drawer
    Licensed copy of Mach3, CamBam and D2NC
    Laptop computer running Windows7 64 bit, monitor, keyboard and mouse
    Braking resistor to allow for power tapping
    1605 ball screws and double ball nuts on X and Y axis
    2005 ball screw and double ball nut on Z axis
    Z axis ball nut carrier mod to minimize backlash
    Extended X and Y axis travel
    One shot lube system
    Full enclosure with overhead lighting
    Flood coolant system including reservoir, pump, spare pump, filter and oil skimmer
    2010 screen set with fixed tool setting plate
    Ultron Snap Change tool changer and tool holders only. Cutters, drill bits and and other cutting or measuring devices are not included
    Auxiliary high speed spindle (24000 rpm) with PID controller
    Z axis tool setter
    X, Y, and Z axis limit and home switches
    All equipment manuals, configuration instructions, and notes included
    Manual mill components removed for the CNC conversion included
    May 2020
    Re: Precision Mathews PM-932 CNC Milling Machine
    How much are you asking and where are you located?
    Jun 2018
    84
    The mill has been sold.
  1. Replies: 47
    Last Post: 12-14-2018, 10:03 PM
  2. Replies: 3
    Last Post: 04-12-2018, 08:20 PM
  3. Tormach slant 15 or Precision Mathews 1330CNC
    By tankguykasota in forum Tormach Slant Lathe
    Last Post: 06-02-2017, 04:19 PM
  4. Replies: 1
    Last Post: 02-02-2017, 09:01 PM
  5. precision mathews and busy bee 11 x 27 lathe HELP
    By bluecollarcult in forum Uncategorised MetalWorking Machines
    Last Post: 12-10-2012, 08:50 PM
