585,938 active members*
3,343 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > Linuxcnc/DYN2 DMM-Tech Drives using 5I25 _ 7I76 Combination
    Apr 2005
    1268
    Wow, after using Mach for so long I decided to change my router to the above Mesa Dmm-Tech configuration. I've heard great things about Linux and am currently running PathPilot on my Novakon Torus Pro. I'll be the first to admit that when I switched the Novakon, it was Monkey see - Monkey do recipe following from threads on this forum. I finally have it working and love it.
    A few years ago I purchased a DMM-Tech Dyn2+750 watt servo system along with their BOB. I want to dabble with a tool changer so I decided to use a 7i76 daughter board instead of the DMM BOB which has limited I/O's. With the new Mesa combination installed in a new control panel, I have spent two weeks attempting to get motor movement with littel success. I have searched for hours on the forums trying to find a thread I could understand that addresses this combination. Again, I have very minimal linux experience.
    I contacted DMM-Tech and they provided a schematic (basic) for wiring the 7i76 to the DMM2 drives. I've wired as depicted on the diagram but am having issues understanding the pin 7 (common) connection to TB6 Pin 1 Input0 which is identified on the drawing as a "sinking input". Whey using the pncconf configuration editor in the linuxcnc software, the 7i76 pin 1 selections does not have a "sinking input" choice. It list about everything else but no sinking input. Also, I have not added any additional wiring except that depicted on the diagram.
    OK guys, what am I missing and if I'm completely out of the park, where can I start. I've been on the linuxcnc.org site many times but their "getting started" manual is above this 67 year olds ability to comprehend.
    Any help or advice will be appreciated.
    I'll attach the PDF diagram for reference.
    Many Thanks.
    Bill
    Attached Files Attached Files
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Feb 2008
    644
    Re: Linuxcnc/DYN2 DMM-Tech Drives using 5I25 _ 7I76 Combination
    If the Dyn2 requires a 5V control signal for enable, I would run the 7I76 field I/O at 24VDC and instead use some
    free 5V step/dir pins for the drive enable (assuming you are not using all 5 axis) This is done by using the GPIO pins:
    for example gpio.008 controls the Step04 output (if stepgen 4 is disabled, that is you are only using 4 axis)
    Since this is very specific LinuxCNC configuration and setup related, I think you would be better off asking
    how to do this on the LinuxCNC forum
    Also I seem to recall that the DYN2 enable signal is actually a disable ( enabled when un-driven )
    If thats the case you should be able to get machine motion even with it disconnected, and the
    alarm output is a nice feature, but will not prevent motion is not connected
  1. Linuxcnc Mesa 5I25 + 7i76 5v Enable signal
    By Tkamsker in forum LinuxCNC (formerly EMC2)
    Last Post: 11-05-2016, 09:38 PM
  2. WTB: 1 5i25 and 1-2 Mesa 7i76 Boards Cash/Barter
    By Contract_Pilot in forum Want To Buy...Need help!
    Last Post: 12-13-2015, 05:09 AM
  3. Replies: 4
    Last Post: 01-08-2015, 06:20 PM
  4. MESA 5i25-7i76 Spindle Issue
    By johnjsb in forum LinuxCNC (formerly EMC2)
    Last Post: 07-18-2012, 11:14 PM
  5. Mesa 5I25+7i76 5V I/O
    By dicker in forum LinuxCNC (formerly EMC2)
    Last Post: 06-08-2012, 10:19 PM
