585,930 active members*
3,560 visitors online*
    Jul 2005
    207
    Question Mycenter 0 way lube?
    I am doing a full retrofit of a 96 Mycenter 0 Changing out all the lube lines as many were broken or plugged up. Also testing all the metering valves for flow. I am having trouble identifying the way lube originally required for this machine. It appears its OEM was "tellus 68" but I am not too sure. Being that I use Vactra 2 for all my other machines I am wondering if this is a suitable lube for this one? As far as I know Vacta 2 is ISO 65 with added tackifiers. Tellus 68 is a hydraulic oil vs Vactra 2 being a way lube oil. Seams it would be a better match. Any issues running this stuff in these?
    Jul 2010
    7
    Re: Mycenter 0 way lube?
    Mobil Vactra No. 2 is what I use also. I used an off brand for several years but it clogged up the lines and metering valves. I had to replace the (Y) axis linear ways and slides when the problem was found.
    Jul 2005
    207
    After tearing the whole system apart it appears that Y axis was never lived by oil. They used a grease. Any idea what grease this was? I may attempt to lube it with oil like the others.
  1. Arrow 500 Spindle Lube Fault - where is the lube?
    By Joe Miranda in forum Cincinnati CNC
    Last Post: 07-20-2019, 11:47 AM
  2. Considering a Mycenter 4
    By MBX5 in forum Kitamura
    Last Post: 03-25-2015, 05:57 AM
  3. Replies: 3
    Last Post: 03-04-2012, 10:42 PM
  4. I got a new to me Mycenter 4
    By CarTunr22 in forum Kitamura
    Last Post: 02-20-2012, 11:43 PM
  5. re Spindle Lube and Lube Pump
    By robkuhi in forum Tree
    Last Post: 10-24-2011, 06:49 PM
