585,775 active members*
4,119 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Long hand can cycle drill?
    Feb 2006
    992
    Anyone know how to get Surfcam spit out long hand can cycle? Right now, it going like this G98 G81 Xxx Yxx R.1 and because I have home made machine will not understand can cycle and it only will take do simple G0 G1 G2 G3
    Example:
    G0 Xxx Yxx
    G1 Zxx
    G00
    Etc....
    Help me !
    I know Mastercam can do that....... I want to understand it with Surfcam. Thanks
    The best way to learn is trial error.
    Re: Long hand can cycle drill?
    Hi CNCRim:
    Here is the answer for you, from the Surfcam Help Book
    Emulated Can Cycles:
    When built-in machine canned cycles are not available, the cycles can include any desired code that is to be repeated at each location. Since these cycles are not built-in canned cycles, the machine tool does not require a Cancel code. Define a straight drilling cycle by describing the Drill sequence as follows:
    Drill
    G0 X[h] Y[v] Z[rplane] # Rapid to position Rplane.
    Z[vclear] # Rapid down to clearance.
    G1 Z[d] F[plunge] # Feed down to bottom.
    G0 Z[rplane] # Rapid out to Rplane level.
    End
    The output code:
    G0 X1. Y1. Z.2
    Z.1
    G1 Z-.5 F5.
    G0 Z.2
    G0 X2. Y3. Z.2
    Z.1
    G1 Z-.5 F5.
    G0 Z.2
    G0 X3. Y4. Z.2
    Z.1
    G1 Z-.5 F5.
    G0 Z.2
    Good luck.
    Mario.
    Nov 2009
    From the 2 axis hole process, under the "Cut Control" tab..., in the "Cycle Type" box..., choose "Chip Break" and when you post, it will come out "long hand"
    Feb 2006
    992
    Quote Originally Posted by TonyKoke View Post
    Thanks you it work like I want it.
  1. Tapping. G84 or Long-hand?
    By RussMachine in forum Tormach PathPilot™
    Last Post: 04-26-2017, 04:59 AM
  2. Long hand post for an integrex
    By lenny09 in forum GibbsCAM
    Last Post: 11-20-2014, 03:07 PM
  3. Haas TL1 IPS or Long hand or DFX?
    By cpmfastools in forum Haas Lathes
    Last Post: 04-24-2013, 12:34 AM
