I just get an P1 by now i repair all mechanical stuff and is working ok but ATC not work at all, if i get separated comands and go to ATC manual it works it go home and go fwd and reverse but no creep speed, no orient i think ATC macro is corrupt or something in configuration. Now i get an extra HDD and make an back-up system also left original HDD as back up and now is running under compact flash memory, but ATC not run i check orient sensor, TC sensors, TC valves and all work ok and in diagnostic windows it shows working, if some one with a machine working can share me a system back-up or configuration back-up i think could solve problem. When i get this machine it has an x encoder wire damaged and machine was junked now is alive just need ATC fix.
I will preciate any help.
JP
