585,712 active members*
4,099 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > PLEASE HELP!! hardinge chnc1 battery replacement
    May 2009
    7
    hello everyone I bought a hardinge chnc1 lathe about a month ago
    finally powered it up the other day on the screen it says battery alarm power
    i assume i need to change the battery can anyone tell me exactly where it
    is located it has siemens controlls
    Aug 2009
    1570
    Re: PLEASE HELP!! hardinge chnc1 battery replacement
    ....If, possible Backup any parameters, programs, etc before replacing battery. Quick search found this thread about 810T machine...
    https://www.cnczone.com/forums/hardi...448-posts.html
    Feb 2011
    353
    there could be a coin style battery on the memory board along with the 3.6 volt battery that you access from the back side where the crt is
    if the control got a memory board upgrade then it only uses the 3.6 volt battery
    you replace the battery while the power is on
    getting a back up of the parameters is a good idea before replacing the battery
    machineshop5 gave you a very good link with pictures of the battery's and information
    Mar 2010
    1852
    If you have a Siemens control, it is under the panel that covers the back of the control. Be sure to have the power on before removing the battery cartridge. If that does not fix your problem, there is a battery on one of the boards too. But don't pull boards if you do not need to.
    Mike
  1. Hardinge chnc1 parts for sale
    By hornby chopper in forum Hardinge Lathes
    Last Post: 09-23-2023, 04:14 AM
  2. hardinge chnc1 need help carrige plate missing
    By clamdigger1964 in forum Bridgeport / Hardinge Mills
    Last Post: 01-14-2020, 04:29 PM
  3. Replies: 0
    Last Post: 09-21-2017, 08:41 PM
  4. Hardinge CHNC1 Metric English
    By moonman5 in forum Hardinge Lathes
    Last Post: 04-11-2017, 08:10 PM
  5. Hardinge CHNC1 with Siemens 810T not communicating
    By Artistic in forum Hardinge Lathes
    Last Post: 11-27-2014, 01:35 AM
