585,956 active members*
4,623 visitors online*
    Jun 2017
    143
    TNGv2 Possible bug with (array)
    Since there is no documentation/examples that I can find about (array) I had a guess as to how it works, but have come across some strange behaviour. With the following script I would expect the same results, but they differ.
    Code:
    ; _spindlespeed set to 12000
    (clear)
    (print,This doesn't work)
    (array,4000,SHR[[#<_spindlespeed>*100/60],8],AND[[#<_spindlespeed>*100/60],255])
    (print,#4000)
    #<i> = 0
    O<print> repeat [#4000]
        #<q> = [#[4001+#<i>]]
        (print,#<q,0>)
        #<i> = [#<i>+1]
    O<print> endrepeat
    (print,This does work)
    #<speed_lo> = SHR[[#<_spindlespeed>*100/60],8]
    #<speed_hi> = AND[[#<_spindlespeed>*100/60],255]
    (array,4000,#<speed_lo>,#<speed_hi>)
    (print,#4000)
    #<i> = 0
        (print,#<q,0>)
        #<i> = [#<i>+1]
    O<print> endrepeat
    The output I get is:
    Code:
    This doesn't work
    4.000
    8
    16
    255
    This does work
    2.000
    78
    32
    I don't understand why it is different and the wrong output contains more data than I expected and it seems completely wrong. I hope you can explain.
    Simon
    Mar 2017
    1311
    Re: TNGv2 Possible bug with (array)
    (array) will not evaluate expressions.
    Jun 2017
    143
    Ok. Maybe it should throw an error if you try?
    Mar 2017
    1311
    Ok, error then.
  1. TNGv2 for Mac OSX
    By tantemay in forum PlanetCNC
    Last Post: 08-24-2023, 07:12 PM
  2. [TNGv2] - Expr.txt
    By PlanetCNC in forum PlanetCNC
    Last Post: 05-29-2023, 06:20 PM
  3. [TNGv2] - 2019-11-08
    Last Post: 11-09-2019, 02:15 AM
  4. [TNGv2] - 2019-10-28
    Last Post: 10-28-2019, 04:52 PM
  5. [TNGv2 - API]
    Last Post: 10-27-2019, 11:23 PM
