585,937 active members*
3,983 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco VMX24 ULMax 4 error servo drive AL10
    hi
    i have problem with Hurco ,sometimes works 1 day ,sometimes works 5 days,sometime works couple hours ,
    today i turn on machine works couple hours and receive on the display servo Y faulty on the monitor,in cabinet on the servo Y is AL10,sometimes i get faulty X axis and alarm AL10 on servo ,one time i receive faulty Z axis and AL10
    please helpClick image for larger version.
ID:	436588Click image for larger version.
    Apr 2019
    58
    Re: Hurco VMX24 ULMax 4 error servo drive AL10
    Check what al10 means in servo catalog
    [email protected]
    +37060022992
    Feb 2020
    I think it's an over temp alarm. Usually this means that the fan inside the servo has failed and the heat sink is overheating. If you are getting this on multiple axes then try opening up the cabinet a crank and see if better airflow through the electrical cabinet makes it go away. The actual alarm may be listed as an over current alarm, and if its not the fan, then it can be tested by swapping all of the wiring from the x to the y axis and running the machine. If the error swaps to the y axis then its either the motor or cables from the servo amp to the motor. If it stays on the x axis then you need a new servo or need to rebuild the one you have.
  1. Need Help VMX24 servo fault at both axis
    By els_engineering in forum HURCO
    Last Post: 01-22-2021, 02:59 PM
  2. Replies: 1
    Last Post: 02-15-2020, 05:17 AM
  3. Hurco VMX24 control kit Won't booting
    By KangMus in forum Milling
    Last Post: 02-14-2020, 07:55 AM
  4. NEED HELP! Fault Code x-axis (HURCO VMX24)
    By wolfyy98 in forum HURCO
    Last Post: 01-03-2013, 01:56 PM
  5. Hurco VMX24 ATC Overload Fault
    By Doug E. Hurco in forum HURCO
    Last Post: 12-27-2011, 08:32 PM
