585,727 active members*
3,982 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Need Help!- Huanyang VFD + Usb 4 Axis Mach3 100 Khz Usb
    Oct 2019
    4
    I have this controller Usb 4 Axis Mach3 100 Khz Usb, and Huanyang VFD, I tried everything, but it didn't start some help ?
    Attached Thumbnails Attached Thumbnails s-l1600.jpg   IMG_20200215_073320.jpg   IMG_20200215_073343.jpg
    15362
    Re: Need Help!- Huanyang VFD + Usb 4 Axis Mach3 100 Khz Usb
    Quote Originally Posted by taths View Post
    Do you have a wiring diagram you can post of the Breakout Board, it does not appear to have a Relay or PWM 0-10v analog output
    Mactec54
    Oct 2019
    4
    Thanks for the answer, photo with connectors,sorry for my english, i use translation.
    15362
    Check that the ACM and DCM are the same if not they can not be connected / wired like that ACM is Analog Common DCM is DC Common
    FWD and output 2 I don't think will work for your VFD Drive, what does output 2 do, if this has voltage then it will not work it would have to turn a Relay On / Off to be used if it has a voltage FWD and DCM is just a switch with no voltage to make the VFD Drive turn On / Off
    Mactec54
  1. Replies: 10
    Last Post: 11-14-2023, 07:17 PM
  2. Replies: 41
    Last Post: 03-15-2023, 01:14 AM
  3. huanyang vfd and mach3
    By Elektryk in forum Phase Converters
    Last Post: 07-29-2013, 05:14 AM
  4. Huanyang 2.2kw VFD PWM Mach3
    By Kkatkhuda in forum Phase Converters
    Last Post: 11-14-2012, 02:31 PM
