585,948 active members*
3,931 visitors online*
    1530CNC and Mach 3 settings
    I picked up one of the 1530 CNC from China with Mach 3 software. They gave me specs to configure the setting's, however when I run program the cut is smaller. I believe they set it up in MM, however I would prefer for inches however changing it under Mach 3 does'nt make a difference. So right now doing everything in Metric and still not cutting the correct size. I moved the CNC 1000mm and it moved 31 1/2 inches which would be 800MM. So believe the motor setting's are wrong. Does anyone have the correct settings that I would need for Mach 3 for the 1530CNC Machines? Thanks in advance!
    Jul 2007
    11
    Re: 1530CNC and Mach 3 settings
  1. Mach 4 settings ???
    By Cmac139 in forum FineLine Automation
    Last Post: 10-14-2018, 08:42 PM
  2. Migrating Mach 2 to Mach 3 settings
    By brian257 in forum Mach Software (ArtSoft software)
    Last Post: 06-10-2014, 02:06 AM
  3. cnc settings in mach 3 for usb
    By DENTSDINGS in forum Benchtop Machines
    Last Post: 09-17-2013, 11:31 PM
  4. Mach Settings
    By ltcjr71 in forum Charter Oak Automation Support Forum
    Last Post: 03-26-2010, 06:53 PM
  5. Mach 2 and settings
    By tauscnc in forum Commercial CNC Wood Routers
    Last Post: 05-25-2005, 03:05 PM
