585,883 active members*
5,827 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Parameters for a Miyano BND 34s Fanuc 31-T. can't generate a adius.
    We had a board go out on our Miyano BND 34s with a Fanuc 21-T control. With the Help of Fanuc and Local Miyano service, We have the machine up and running, but it doesn't generate a Radius. We bought the machine used and found out that we didn't have the parameters for the machine. fanuc entered parameters they thought would work. Miyano hasn't been able to help.
    We have a program that uses a G03 X.75 Z-.05 R.05. And the machine does a big radius away from the part on the Z axis and then way above on the X axis and stops at the end point but doesn't come close to the part.
    Program Example:
    G00 X.85 Z0.1
    G00 X.65
    G01 Z0 F.005
    G03 X.75 Z-.05 R.05
    G01 Z-1.0
    X.8
    G00 X7.0 Z7.0
    M01
    Feb 2020
    4
    Re: Parameters for a Miyano BND 34s Fanuc 31-T. can't generate a adius.
    Quote Originally Posted by larryre59 View Post
    Program Example:
    G00 X.85 Z0.1
    G00 X.65
    G01 Z0 F.005
    G03 X.75 Z-.05 R.05
    G01 Z-1.0
    X.8
    G00 X7.0 Z7.0
    M01
    What does the machine do with the following
    G0 X.85 Z0.1
    X.65
    G1 Z0 F.005
    X.75 R.05
    Z-1.0
    G0 X7.0 Z7.0
    M01
  1. Parameters for Miyano BNC34T with Fanuc OT-A
    By DPMINC in forum MetalWork Discussion
    Last Post: 06-05-2019, 06:22 AM
  2. Miyano BNC-34S with Fanuc 0-t control missing Parameters
    By dxhop03 in forum CNC Machining Centres
    Last Post: 01-30-2019, 08:05 AM
  3. miyano bnc34t parameters
    By Gabbriel in forum Fanuc
    Last Post: 02-24-2015, 08:27 PM
  4. Miyano MSV-21 Parameters
    By billay in forum Uncategorised MetalWorking Machines
    Last Post: 07-06-2011, 06:50 PM
  5. Fanuc 3t parameters miyano
    By Progress Nc in forum Fanuc
    Last Post: 11-28-2008, 04:04 PM
