585,906 active members*
3,949 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Parameters for a Miyano BND-34 for Radius Problem
    We had a board go out on our Miyano BND 34s with a Fanuc 21-T control. With the Help of Fanuc and Local Miyano service, We have the machine up and running, but it doesn't generate a Radius. We bought the machine used and found out that we didn't have the parameters for the machine. fanuc entered parameters they thought would work. Miyano hasn't been able to help.
    We have a program that uses a G03 X.75 Z-.05 R.05. And the machine does a big radius away from the part on the Z axis and then way above on the X axis and stops at the end point but doesn't come close to the part.
    Program Example:
    G00 X.85 Z0.1
    G00 X.65
    G01 Z0 F.005
    G03 X.75 Z-.05 R.05
    G01 Z-1.0
    X.8
    G00 X7.0 Z7.0
    M01
    Any help would be appreciated. Thank You
    Dec 2009
    952
    Re: Parameters for a Miyano BND-34 for Radius Problem
    first of all i should try to run the cycle with SINGLE BLOCK activated and check the values onISTANCE TO GO page and when start the radius check where is going and make an analogy
    second ,try to see if you do not have some scalling factor activated or some mirror in operator page
    make a small video showing us the screen with the all coordinates:absolute,machine,distance to go and also show us what it has to do and what it really does.
    maybe with this info we can have some ideas of what is going on.
    also paste here the 9000 parameters to see hwta options you have activated.
  1. Miyano BNC34 Parameters
    By Mark18969 in forum Fanuc
    Last Post: 07-20-2022, 01:07 AM
  2. Lost parameters on Miyano bnc-34t
    By franek in forum Machinery Manuals / Brochures
    Last Post: 07-20-2022, 01:05 AM
  3. Miyano BNC12S Parameters
    By enjoymfg in forum Fanuc
    Last Post: 12-03-2019, 05:03 PM
  4. Miyano BNC12S Parameters
    By enjoymfg in forum Tormach Personal CNC Mill
    Last Post: 09-03-2015, 08:55 PM
  5. Miyano MSV-21 Parameters
    By billay in forum Uncategorised MetalWorking Machines
    Last Post: 07-06-2011, 06:50 PM
