584,871 active members*
5,121 visitors online*
Results 1 to 6 of 6
    Jul 2005
    450
    sieg X3 spindle motor specs
    Does anyone know what the specification for the spindle motor is on a standard X3? I bought mine from axminster.co.uk, and the only markings on the motor are the AC power requirements of the mill.
    Is it a perm. magnet DC brush motor? what voltage / current / power is it?
    24216
    Quote Originally Posted by daedalus View Post
    They are probabally like Rolls-Royce when you ask them for the H.P. of their engines, They just say 'Sufficient'
    Al.
    Albert E.
    Jul 2005
    450
    Al, im hoping to replace the control pcb with a dc servodrive, so i can set the spindle speed in software, and so that when i eventually dispose of the motor and add a servo my wirings already done. I understand that this wont be as good as using an actual servo motor, but im hoping its good enough to get me started.
    Unfortunately i cant spec the power supply and drive to be "sufficient" without a bit more by way of details
    24216
    There are some test you can do as I pointed out in this post http://cnczone.com/forums/showthread.php?t=39864
    If the present motor is PM DC and not universal, the controller is probabally full wave bridge with scr control.
    If you can get a step dir to analogue convertor and it is isolated, you may be able to replace the speed pot with one on the present drive.
    I am just working on one to isolate analogue to analogue for these type of drives like KB make. You can pick them up on Ebay cheap and they take a tach input, if you put a tach on the motor, you can obtain precise control using a simple controller such as the KB.
    If yours is a SCR drive fed from 240 in your case, then it is most likely a 180vdc motor.
    Al.
    Albert E.
    Jul 2005
    450
    Al, if you want to isolate an analog signal this is probably the cheapest option (bar rolling your own), as it will take a 0-5v analog input and produce an isolated analog signal:
    http://homanndesigns.com/store/index...products_id=21
    24216
    Thanks, But mine requires ±10vdc in ±10vdc out.
    Al.
    Albert E.
  1. Sieg X3 Spindle motor
    By rcotteleer in forum Benchtop Machines
    Last Post: 09-29-2010, 09:25 PM
  2. Sieg X3 spindle problem (?)
    By kevin.doherty in forum Benchtop Machines
    Last Post: 05-19-2007, 03:09 AM
  3. Problem with Sieg spindle board
    By jfmichel in forum Syil Products
    Last Post: 02-23-2007, 10:11 PM
  4. Sieg X1 Spindle
    By itsme in forum Benchtop Machines
    Last Post: 01-24-2007, 01:05 AM
  5. Spindle speed for Sieg conversion
    By rcotteleer in forum Mach Software (ArtSoft software)
    Last Post: 01-09-2006, 07:29 AM
