585,752 active members*
4,213 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machine home altered after play with toolpath viewer while cutting
Page 1 of 2 12
Results 1 to 20 of 28
    Mar 2019
    51
    Question Machine home altered after play with toolpath viewer while cutting
    Hello, i'm new to cnc and software, still playing around.
    It was doing a 3d finish operation, near the end of the gcode i wanted to see how many passes/width still left, so i lead to mach3 toolpath preview window and left click and drag, left click, right click, double click, middle click, so basically i tried everything there with the mouse. Then when i got the desired preview i notice the machine not on right Y, i stop machine right away and check stuff. I send a Go To Zero to check home and home was altered in Y, it was some cm lower than expected.
    What caused such problem?
    Mach3 with LTP. First time this happen just because i mess arround with preview window.
    Here the disaster:
    Attachment 436912
    Nov 2012
    1267
    Re: Machine home altered after play with toolpath viewer while cutting
    It is generally not a good idea to mess with an LPT-based CNC computer while the program is running. Windows is not exactly a realtime operating system, so playing with the preview may have upset the timing and made the Y axis lose steps.
    Nov 2013
    4361
    fiddling with the toolpath viewer while the machine is running is an absolutely sure way of losing steps. Even toolpath regens can cause the machine to stutter or stall.
    With BIG Gcode files the advice is to turn the toolpath viewer off, the large amount of data in the toolpath demands to much CPU time and therefore Machs
    parallel port gets starved of service and stutters or stalls.
    Craig
    Mar 2019
    51
    Thank you all. Good to know the culprit.
    I'm also improving my machine which come with a very basic ltp control board. For just two times the machine just stop without reason and stop response to mach3, had to close and restart mach3 to machine start response again, for my luck i was able to continue from that point and nothing bad happen, still is not the type of thing i want to happen.
    What control boards out there do you guys recommend?
    Nov 2012
    1267
    I do not have any practical experience with it, but I'm thinking about trying AXBB-E for my next machine.
    Mar 2019
    51
    Quote Originally Posted by CitizenOfDreams View Post
    look's sexy, it still need mach3 to send out commands right? So still can be affected by the computer and buffer or it have some kind of integrity?
    Nov 2013
    4361
    I'm not sure that the AXBB-E even has a Mach plugin and it doesn't have a mach4 plugin. Being made by CNCDrive it is natively a UCCNC controller.
    I use an Ethernet SmoothStepper and Mach4, light years ahead of Mach3.
    Craig
    Yes, the AXBB-E has both a Mach3 and Mach4 plugin
    Mar 2019
    51
    I don't care about mach3, if i upgrade i would go for the better.
    Mach4 or UCCNC, what would be the better move?
    Depends on what you want it to do, and who you ask.
    Mar 2019
    51
    3 axis steel 6090 cnc router, i cut wood and aluminium
    For now i work only with simples cuts and this engravings, nothing special. I'm a simple cnc user.
    I use aspire and Inventor HSM
    Just want something stable, future proof, problem free
    Eletronics, software and programming are not a problem for me
    Price difference is not a problem
    Nov 2013
    4361
    both Mach4 AND UCCNC are very good with little to separate them.
    CNCDrive make their own controller and is therfore superbly intergrated with their own UCCNC software.
    NFS (Mach4's makers) do not manufacture motion controllers, they rely on third party vendors. This means competition
    but also means there is a spread of performance and features and prices.
    Mach4 enjoys a very flexible structure, flexible GUI, powerful scripting language/ API. This allows OEM's particularly to customize Mach to their needs.
    That may appeal to you. In addition if you wish to write your own plugin for a piece of hardware, you can with an NDA (Non-Disclosure Aggreement) get
    all the inside information to do so. Again this may appeal more to manufacturers than yourself.
    I would double check with CNCDrive about the plugin status for their new release ABXX-E. As of a short while ago it did NOT have a Mach4 plugin,
    whereas the earlier UC100, UC300 and UC400 did. It must be said that CNCDrives Mach4 plugins lacked the features and finesse of some of their
    competitors and I would not regard CNCDrive products as the first choice for Mach4 operation but are creditable performers none-the-less. Of course
    they are superb and ABSOLUTELY required to operate UCCNC.
    Craig
    Nov 2012
    1267
    Quote Originally Posted by sn4k3 View Post
    You still need SOME control program, either Mach3, Mach4 or their own UCCNC.
    With an external controller like this, the computer does not have to do realtime "bit banging" anymore, so it is much more reliable than the traditional LPT port. All time-critical calculations and input/output operations are done inside the controller.
    Aug 2009
    1570
    we dont need shinking machines....with lack of control.. dew we cloud control to major tom
    IMO, UCCNC is much easier to setup and learn than Mach4. I like to think of it as a highly advanced Mach3. It has most of the features of Mach3, with none of the bugs. And much easier customization.
    At this time, Mach4 might have a slight edge in motion quality in some cases, but UCCNC is still much more accurate than Mach3 in CV mode.
    CNC Drive is working on an S-Curve Planner for UCCNC, which should make it even better.
    UCCNC is also 1/3 the price of Mach4.
    Mar 2019
    51
    Thank you for explaining this.
    I see lot of good comments about UCCNC. I may go for it as favor of their own software is made for their hardware, so i guess it's a plus.
    About mach4 i see split fellings but i guess it was from earlier versions since i read some old threads.
    About the controller only "joeavaerage" suggested "AXBB-E" which fullfill my needs and look's solid. I also take look at Acorn CNC which seens more advanced but i think AXBB-E will do the same on my use case.
    There are any other suggestions that worth a look? eg: Planet CNC, others?
    15362
    Acorn is the #1 choice
    Eding is 2nd choice
    UCCNC comes in 3rd along with Mach4 and Planet CNC
    Mactec54
    Nov 2013
    4361
    My apologies, I did not offer any alternative controller. The AXBB-E is certainly solid and perfectly matched to UCCNC.
    IF however you were interested in Mach4 then the CNCDrive boards, despite their quality, are not the first choice as there are others for about the same price
    which are equal in quality and have many more realtime features and supports. The leading example is the Ethernet SmoothStepper by Warp9TD.
    Craig
    Jun 2015
    943
    Craig
    The AXBB-E is not only a motion controller, but a high speed breakout board on a single board. So you comparing the price of an apple to oranges.
    With UCCNC it has realtime features like backlash compensation, plasma THC, rigid tapping, thread cutting. I'm using all these features on my machines (except the thread cutting) and all work fine.
    As far as I remember with Mach4 it has backlash compensation, but no THC and no rigid tapping.
    If can't think of any other possible realtime features, but you've mentioned "many more", so please explain what else are you thinking of.
    Jun 2015
    943
    I forgot to mention that in the last few releases UCCNC also has a nice new screen set:
    https://www.youtube.com/watch?v=kyRwk_TQd5w
    But you can switch back to the old screen anytime if you want.
    And a nice probing screen too:
    https://www.youtube.com/watch?v=Bdlkbb3uh-E
    https://www.youtube.com/watch?v=MUaxCJa_9hI
Page 1 of 2 12
  1. Problem with a MAchine Hard Home (Sensors Home)
    By wwagner in forum Chinese Machines
    Last Post: 02-16-2018, 01:35 AM
  2. Replies: 0
    Last Post: 04-04-2016, 07:13 PM
  3. The speed of going home of SteelTailor CNC cutting machine is too big?
    By Steel Tailor in forum Other Machine Topics
    Last Post: 12-13-2013, 03:28 AM
  4. Machine Home in relation to MadCAM Model Home
    By subnoize in forum MadCAM
    Last Post: 08-01-2013, 01:49 AM
