585,754 active members*
3,916 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > I am looking for someone to Beta test a 4th axis fixture
Results 1 to 9 of 9
    Jun 2007
    28
    I've been using this for a while and thing its time to share. I'm looking for someone with a 4th axis who regularly makes parts in the 4" x4" x 4" size range and would like to get to a bunch more sides. I'll pay for shipping you just have to give me feed back. Let me know if your interested.
    contact me at [email protected]
    thanks,
    Jun 2015
    4154
    Re: I am looking for someone to Beta test a 4th axis fixture
    hy, it looks nice ... i believe that it is only for positioning, and it may be used also inside a lathe
    did you crafted it ? kindly
    ps : please, do you have a web link for that fixture sistem ?
    Jun 2007
    28
    Yeah its for 5 axis indexing. You use the full 4 axis to get to any coordinate system you need to and the input an option stop to manually rotate the spindle to one of 8 locations. I get most of my complex parts done in two ops now. I focused on this size of part because most of the parts I do are 4" cubed or less. Here is a video of it
    Jun 2015
    4154
    is nice, at least for vmc+4th axis, and for some milling operations on lathes ( on an y-lathe it would be required to clamp it a bit offset, so to have the part intersecting the spindle center line, in order to use the full y travel )
    it's rigidity can be boosted by using a tailstock
    nice product, good luck
    Apr 2004
    5735
    I'd be interested. I've been working on some parts that need to be cut from various angles, and this might be helpful. But I mostly cut wood, not metals at that scale - is that okay?
    Andrew Werby
    Website
    Jun 2007
    28
    Andrew, I don't think wood will work with a dovetail. Dovetail gripping works great with metal but I bet wood will simply break loose.
    Chip
    Jun 2015
    4154
    it could be possible to clamp not only dovetails; in other words, there should be a way to clamp wood
    this involves changing a bit here or there, but if really needed, then why not ?
    Apr 2004
    5735
    Often, when I need to hold onto a wood part for machining, I screw something to it that's possible to grip in a chuck or fixture. It looks like this clamp works like an Aloris toolpost, so it gets a quick-release grip on a dovetail-shaped piece of metal. Why couldn't I screw something like that onto my wood part? A lot more people are doing 4+ axis carving in wood and other soft materials than are doing it in metal, especially on that scale; figuring out something that helps us with that would increase the market for your product considerably.
    Andrew Werby
    Website
    Jun 2007
    28
    Yes, That would work well actually. But a guy with a large shop had the perfect jobs for it and actually will need several so it is on the way now. I will post some of the things he makes with it. He says he has 5 or 6 parts that he runs constantly that this is perfect. The ease of 4 axis programing but getting 5 axis indexing should save him a lot of operations.
    thanks,
    Chip
  1. beta test my site!
    By Jack000 in forum DIY CNC Router Table Machines
    Last Post: 11-08-2010, 11:46 PM
  2. Beta Test G-Wizard Machinist's Calculator
    By BobWarfield in forum News Announcements
    Last Post: 08-01-2010, 07:53 PM
  3. V12 in Beta Test Now
    By tobyaxis in forum Uncategorised CAD Discussion
    Last Post: 07-19-2009, 07:30 AM
  4. TurboCNC with dual X Axis -beta
    By rlwoodjr in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-14-2009, 10:15 PM
  5. Beta 4th axis on Robodrill Alpha
    By barbter in forum Fanuc
    Last Post: 03-19-2009, 10:09 PM
