585,991 active members*
4,725 visitors online*
Results 1 to 3 of 3
    Feb 2020
    8
    CNC Controller ideas wanted
    Good day Internet CNC Enthusiasts.
    I recently brought home a CNC machine - Owned one about 6 years ago and wanted to tinker in it again.
    This machine is a LOT different than my last one. It is a classic PC running Supercam and instead of a controller it has 3 HUGE transformers along with 3 massive capacitors that supply power to the steppers (or servos) not sure which)
    Then the power goes to 3 separate motion controllers (Accelus Model ASP-090-36 to be exact) The machine works when I manually control it as I have loaded any Gcode yet- still cleaning it up.
    My question if you choose to drop your two cents in is... why have the 3 separate power supplies and motion controllers? Could I consolidate those to 1 power supply and a CNC controller board? In my mind this would be more efficient, simple, less expensive.
    As mentioned the PC that was with it is quite dated running Win XP and Supercam- I am looking to try out Mach4 and potentially get Vcarve (if my budget allows) I am not sure how much life is left but would want to upgrade.
    I understand that the computer is an entirely different arm of the CNC process from the controller but I want to get your thoughts.
    35538
    Re: CNC Controller ideas wanted
    Those appear to be servo drives, probably driving DC servos?
    I'm not sure I've ever seen a multi axis servo drive. You'll always need one drive per motor.
    High end stepper drives are also almost always one drive per motor.
    Multi axis drives tend to be lower powered hobby level drives.
    The reason for the 3 power supplies is because those drives can handle 30 amps per drive, so it's easier to use 3 smaller drives than 1 large 100 amp power supply.
    Feb 2020
    8
    That explains it! Thank you. I appreciate the information. No I will see what I can do about the computer part.
    Thank you!
  1. Replies: 0
    Last Post: 11-01-2019, 05:26 PM
  2. Wanted - Leather cutting ideas
    By evehooper in forum USA Club House
    Last Post: 07-07-2017, 11:24 PM
  3. SX2 milling machine enclosure ideas wanted
    By DarrenUK in forum Benchtop Machines
    Last Post: 10-24-2013, 09:10 PM
  4. R2E3 Retrofit ideas (opinions wanted)
    By legendboy in forum Bridgeport / Hardinge Mills
    Last Post: 01-25-2012, 09:41 PM
  5. 'Artistic' aluminum casting ideas wanted
    By kenny1 in forum Moldmaking
    Last Post: 03-18-2007, 04:33 AM
