585,591 active members*
2,562 visitors online*
    Aug 2015
    Omiocnc x6-2200l spindle not turning
    Thanks in advance for any help. I have had this machine a while and just recently took the cover off after a long slumber and decided to give it a few upgradedes. I added a new computer (not sure what happen to the old one) so I had to do a fresh install of mach3 and files from the distibutor. I set up the stepper motors and checked them and they work flawlessly. I then moved on to the touch off probe and got the z to do what it was suppose to but the digitizer light stays lit and the connection of the tool and plate do not work.(this issue i can live with) Now on to the main issue, the motor will not work. If i recall I had this issue the first time i set it up many years ago, but have no idea what i did to fix it. The spindle does work as I got it to turn on manually with the box (sorry i forgot the name of it) that has the power supply and manual spindle control. I have changed setting after setting and it will not engage throuh mach3. any help on this matter would be great
    Aug 2009
    1570
    Re: Omiocnc x6-2200l spindle not turning
    need more information about your System ..photos would help too
  1. X6-2200L
    By Richster in forum Chinese Machines
    Last Post: 08-26-2020, 01:25 AM
  2. OmioCNC X6-2200L USB - pricing for a used machine
    By erik65 in forum Chinese Machines
    Last Post: 01-06-2019, 03:43 AM
  3. Replies: 0
    Last Post: 09-25-2018, 01:41 PM
  4. omiocnc X6-2200L, bad PSU?
    By Dustmite in forum Chinese Machines
    Last Post: 04-06-2017, 02:15 AM
  5. X6-2200L or... ?
    By Jmac80 in forum Chinese Machines
    Last Post: 10-27-2015, 04:46 PM
