585,585 active members*
3,556 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Using Cplane to view for 5x toolpaths
    May 2006
    343
    I had an earlier post about my post not working correctly. I'm taking that back now.
    My parts are trying to cut inside of a tube. Hard to generate toolpaths for. Best way for me is to move Cplane to view, and generate a toolpaths from boundary curves.
    This results a toolpath that looks great on the screen, but when I try and cut the part, it's off.
    I generated a 5x Z level finishing from world top and it cuts as it should. So my post is working correctly.
    There's a problem with Madcam generating the toolpaths correctly from this Cplane to view.
    Are people having luck using generating toolpaths this way? What am I doing wrong?
    May 2006
    343
    Re: Using Cplane to view for 5x toolpaths
    I'm changing c plane to view in my perspective window. And doing all my work in the perspective window.
    I noticed my top view, front, and right view still are in world top c plane.
    Am I missing something in my Rhino settings, or am I using c plane to view correctly only in perspective window?
    May 2006
    343
    No advice or help?
    Does anyone use c plane to view? Am I missing something?
    Aug 2005
    205
    Its been a while, but if I remember correctly, the c plane is tied to an individual view. If the c plane orientation is correct for your operation in a given view, I believe the tool path will need to be posted from that view. Does that make sense? I'm 4 years away from doing 5 axis work in RhinoCam, so I could be wrong.
  1. G-Code relative to Cplane
    By Hrvoje Petrovic in forum MadCAM
    Last Post: 05-18-2020, 05:41 AM
  2. Replies: 8
    Last Post: 01-02-2014, 04:51 AM
  3. g-view and wcs for HBM
    By dcutler35 in forum Mastercam
    Last Post: 06-08-2012, 08:23 AM
  4. Easily identify a previous T/Cplane
    By PRINT_FX in forum Mastercam
    Last Post: 06-05-2012, 05:30 AM
  5. HOW TO SET X AND Y AS TOP VIEW
    By atlantic23 in forum Solidworks
    Last Post: 06-02-2009, 12:11 AM
