Re: Help alarm 1100 Okuma
hy, i can only help you with next error infos / kindly
1100 Parameters not set
The backup data caused an error and the factory-set initial data was forciby loaded. Machine data must be set again.
[Object]
None
[Character-string]
None
[Code]
XXXXYYYY
XXXX
bit 0:SPARE
bit 1:HD backup status file
bit 2:Low speed NC backup data file
bit 3:High speed NC backup data file
bit 4:PLC backup data file
bit 5:PLC-HMI data file
bit 6:Alarm history data file
bit 7:PLC axis data file
bit 8:POT TOOL data file(M/C only)
bit 9:MOP TOOL data file(M/C only)
bit10:MOP TOOL Parameter file(M/C only)
YYYY
1:File read open error
2:File read error
3:Version check error
4:Check sum error
5ouble check sum error
6:Backup memory check error
7:File write open error
8:File write error
