584,871 active members*
5,427 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Help with Kitamura H-400 - loss of all parameters!!!
    Jun 2018
    Hello! We have a milling machineKitamura H400 with control machine Fanuc 15, 5 axes of control with two interchangeable pallets.
    We have lost all parameters of this milling machine.
    Could anybody help us with table of parameters?
    Sep 2019
    11
    Re: Help with Kitamura H-400 - loss of all parameters!!!
    Your machine supplier should be able to advise. If not, Dan might be able to help you: https://www.practicalmachinist.com/v...ndrummerman21/
    Apr 2015
    8
    Did you find your parameters? I have a similar machine, all of the main parameters except the keep relay parameters. If you didn't find them, I can send what I have. If you did, can I get a list of the keep parameters?
    Jun 2018
    20
    Hello. Is the machine's problem solved?
    Maybe I can help if you send me photos of model, label and machine.
    +905357221418 whatsapp number
    I just found this thread, was the problem solved? I have a backup of my H400 15m parameters. Can't guarantee everything is the same, but its a good start
