585,687 active members*
4,675 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > New to me Fagor 8025M, how to start spindle, execute some MDI?
    Feb 2004
    84
    I just got an old but very nice Standard Router brand 4x4 CNC router with a Fagor 8925m control that I'm going to do a retrofit on, probably to Centroid. I'd like to run it first to see what works and what doesn't as I've been told there were some intermittent issues, and to download the parameters & stuff that might be of use to someone. The former owner (who last ran the machine about 8 years ago) had this machine connected to a PC via rs232. I can start the machine and jog the axes, but I can't figure out how to start the spindle, and the former owner doesn't remember how to operate the machine, having moved on to much more modern equipment. I'd be OK with merely running the (two) spindles, if for nothing else to make sure the AC drives for them are fine without wiring them up on the bench. There are some old programs in memory but scrolling thru I don't see any m03 or s lines, and I can't figure out how to load them. Not being familiar with this control I'm not sure how to do MDI on it, if someone could give me basic navigation info from the starting page to be able to just get started would be great. I tried m03 s6000, s6000 m03, etc but I can only jog axes and not get the control to accept an actual line of code, even with the aid of the user manual at http://www.fagorautomation.com/downl...8025m_user.pdf .That said I'm primarily used to running an old boss bridgeport running mach3- mostly just code from CAM rather that MDI at the control. I'm also going to replace the PLC and control batteries as they are surely near their end, and have taken phone pics of all the parameter pages I can find. Anyone know how to run this?
    See my stuff for sale at http://stores.ebay.com/Industrial-Tool-and-Machine-Works?refid=store
    Jul 2019
    4
    Re: New to me Fagor 8025M, how to start spindle, execute some MDI?
    Hi Tom!
    Same here, i'm unable to start the spindle!!
    I've other question:
    Have you found a solutions for backup the parameters of the machine? In wich menu can i found it? I need to backup also the Iverter parameter but i don't know how to do it!
    Can you help me?
    Thanks!
    Attached Thumbnails Attached Thumbnails 20190625_191922.jpg   20190625_191942.jpg   20190625_191952.jpg   20190712_175801.jpg
    Feb 2004
    84
    I was not able to find a solution, but I took photos of each parameter screen. I just removed everything to prepare for a centroid all in one retrofit. I was going to retain the servo drives but will just sell them to offset the purchase of the centroid. While I'm at it I may even replace the spindle drive with one that accepts single phase input then the whole machine will be single phase....
  1. Fagor 8025m, ERROR 000 ???
    By ferrumdg in forum Fagor Automation
    Last Post: 11-01-2022, 12:04 PM
  2. fagor 8025m parameters
    By SHEGAL in forum Fagor Automation
    Last Post: 06-30-2017, 08:55 AM
  3. Fagor 8025m cnc
    By gunther kempin in forum Community Club House
    Last Post: 07-24-2013, 10:33 PM
  4. Fagor 8025M CONTROL help
    By ktk11 in forum MetalWork Discussion
    Last Post: 11-10-2010, 09:17 PM
  5. Fagor 8025M error 072
    By Mike Ball in forum Uncategorised MetalWorking Machines
    Last Post: 12-08-2006, 05:13 PM
