585,719 active members*
4,017 visitors online*
    Aug 2015
    work offsets help
    Hey all and thanks in advance for the help. I am trying something new with the waterjet (new to me). We usually just cut out parts and that is the same same. I got a job with alot of flat bar pieces 2 inches wide that need holes drilled in them . I want to do it on the waterjet to save time and alot drill time. my issue is I am unsure how to set up my table and zeros for this to happen. I have what i call a 90 degree fence so parts will start at the same spot. How do i set my zero to make this happen. I am using omax layout to draw the parts and omax make to cut.
    Jan 2020
    47
    Quote Originally Posted by raymond2688 View Post
    Hi there.
    I would draw my profile complete with the outside and the holes then path. then make a break in the bottom left corner, maybe about 1/4" up and 1/4" to the right then draw a traversed line from the bottom left corner to the first hole lead in. Then delete the two divided parts.
    I could draw up an example and email over if you wish to do this over email. Hope this helps
  1. Fauna 21T tool offsets and work offsets
    By tar356 in forum Fanuc
    Last Post: 09-22-2017, 12:44 PM
  2. Replies: 2
    Last Post: 12-23-2015, 05:52 PM
  3. Using Work Offsets
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 06-05-2015, 07:18 PM
  4. Help understanding work offsets and extended work offsets
    By tomvoutsas in forum Tormach Personal CNC Mill
    Last Post: 09-20-2013, 06:35 AM
  5. 3 Work Offsets?
    By KUWill in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-07-2012, 08:19 PM
