We just got a new lathe in our shop with the Fagor 8055i control and was wondering if anyone has added a handwheel to there's.
If anyone can help me out it would really be appreciated.
Thanks Mike
Thanks Mike
Check out Fagor Automation's website, you can download all the OEM manuals for free. Yes you can easily add a hand wheel, there is a dedicated socket for one. The cheap and cheerful Ebays ones will work well. It uses standard A B encoding. Dave
I was referring to a socket on the axis module, if it is a 8055i it will be marked X5, the earlier 8055 model uses X5 or X6 depending on parameter setting, it is all in the documentation along with the pin connections and parameter settings for the hand wheel. Dave
