Im looking for your help- i am looking for the right technology for processing iron cast round bodies. The messurments varry from 200mm diameter to 900 mm, width/hight 900mm.
The procesing should incorperate radial milling, drilling, tapping ( up to 1" unc)and boring the center. Somtimes cone/ slopes inside the body.
I am at a point i need to find one machine to do all of the above, and need to choose between lathe with live tooling (slant or flat bed), vertical or horizontal or milling centeres.
The part weight between 50-150kg.
I would appriciate your expirienced advice
