586,009 active members*
4,884 visitors online*
    May 2007
    32
    RFQ - Turned Steel Adapter
    Fairly simple turned steel part. Unfortunately I only need 1 piece of this in steel (any grade), so I realize price will reflect that some.
    The inner 2.5mm x 45° chamfer/taper is critical. The outer one is just an oversized edge break. There are a couple other important dimensions/tolerances.
    I've attached the drawing, and can provide 3D models if you'd want.
    PM or email me.
    Sep 2009
    135
    Re: RFQ - Turned Steel Adapter
    Todd
    I have sent you an email.
    G28 Machining.com
    Mike Cooper
  1. RFQ - Simple Turned Steel Spacers
    By LateNight72 in forum North America RFQ's
    Last Post: 09-01-2022, 06:43 AM
  2. Need Small Parts Turned in Mild Steel
    By mikegiraud in forum North America RFQ's
    Last Post: 03-08-2016, 12:52 AM
  3. RFQ turned steel rod, easy job
    By sidernik in forum RFQ (Request for Quote)
    Last Post: 01-23-2012, 09:15 PM
  4. Small Steel Plasma and Turned Pieces
    By clintster442 in forum Employment Opportunity
    Last Post: 01-27-2011, 05:13 PM
  5. RFQ on turned steel parts
    By TheGreenMachine in forum Employment Opportunity
    Last Post: 11-12-2010, 07:15 PM
