Originally Posted by
Fortune7
Thanks, Mike for the quick response. I tried that (Something like ADMIN VIEW SOFT LIMITS / ADMIN SET X LIMIT XXX) but didn't get far in changing them, despite re-starting the controller afterwards. After some research it seems I have to edit the soft limits line in the machine's ini (initialization) file. Once done, they stay in place until the next software update. I just can't find a way to get to the ini file in the controller's file system. it's not a folder which can be viewed from the pathpilot 'file' tab. I think there's some combo button holds to press while starting-up, or while in PP, just can't find out how!
If you know the soft limits can be changed from the MDI line, apologies, I obviously haven't found the right sequence of actions to get it done!
Cheers, Andy
