585,987 active members*
4,210 visitors online*
IndustryArena Forum > MetalWorking Machines > Auto Tool Changer > I need help to solve a ATC issue on a machining center
Page 2 of 2 12
Results 21 to 37 of 37
  1. #21
    Mar 2020
    17
    Smile Re: I need help to solve a ATC issue on a machining center
    Quote Originally Posted by kike_c View Post
    Which are these machine condition ?
    What is next logical step?
    Which are diagnostic bit I should check ?
    Hello Guys,
    Any suggestion for questions listed above will be highly appreciated.
    Thank you.
  2. #22
    No apologies and no need for sorrow friend.
    We all learn something.
    The moment you recognize you don’t know something, is the very same moment you begin to know something. ????
  3. #23
    Mar 2020
    17
    It is true and you are right, Kelsang-Lungta.
  4. #24
    Jan 2017
    23
    in fanuc it is table of tools maybe yoiu want to take tool that doesn't exest in tool table?
    Hurco BMC 2416
  5. #25
    Mar 2020
    17
    Quote Originally Posted by noexit View Post
    I tried with twenty different tool number, from T1 to T20. Maybe the tools have a different name, but i do not find a tool screen or tool list.
    If anyone can apoort a machine parameter to initialize tool magazine counter it would be great!
  6. #26
    Can you take a photo of your control panel and attach it?
  7. #27
    Mar 2020
    17
    Quote Originally Posted by Kelsang-Lungta View Post
    Hello Kelsang-Lungta,
    I attached two pics, control panel and display with user message.
  8. #28
    A message like that is going to be MTB defined. It would be in your manufacturer's error code books if you have them. To me that sounds like a physical sensor mounted on or near the tool carousel that counts the carousels individual rotational movements. This could be disconnected or have wet or broken wires or missing completely. To me this does not sound like a missing parameter issue but a control not getting the carousels movement information it needs to know what tool is in what position. It is confused.
    Just my take on it.
    What's funny in this situation is the MTB spelled Magazine wrong. Hilarious!
  9. #29
    Mar 2020
    17
    Quote Originally Posted by the_gentlegiant View Post
    Just my take on it.
    I noticed that it's possible to rotate tool magazine in manual mode (there are 3 proximity sensor mounted on tool magazine ).
    I checked the three corresponding signals on the diagnostic screen and bits changed from "0" to "1" or vice versa for each proximity sensor.
  10. #30
    Well bit changes like that pretty much shot my idea down.
    Does it say anything in your books about the 2008 error code? If you do not have the books, have you also tried to Google search it?
    I think you're soo close. Something is holding it up. Does this machine have a ladder you can look at? That should tell you something.
    Running out of ideas.
  11. #31
    Aug 2009
    1573
    ...can get some photo;s of the I/O PCB board Cables plugs..etc,...maybe the MTB marked them with the M Codes for the TC or loose plug.......one more thing to check for is there an Encoder on the Tool carousel?
  12. #32
    Mar 2020
    17
    I have three, the connecting manual, operator's manual and maintenance manual, but incredibly there is nothing.
    I tried with google, some first issues were solved. However, I did not find information about ATC issue for yasnac mx1 controller.
    regard to ladder, there is also nothing in the manuals. This machine was manufactured around 80's. Maybe I will need assistance of a technician with experience in very old machines.
  13. #33
    Mar 2020
    27
    Hello everybody,
    I'm trying to start up again with a machining center unused for 5 years or more. The equipment in question is a kuraki machining center, kv-500 model with yasnac mx1 controller.
    I solved some initial issues. Up until this point I can send the machine to first reference position, second reference position, spindle orientation,
    move in Manual, JOG, ATM or MDI mode. Unfortunately for me, I encountered a problem that I cannot solve and this gives me many sleepless nights.
    When I enter the code M06 TXX for the tool change, the following happens:
    1.- The spindle orientation occurs.
    But the machine does not move to second reference after this and a "M"and a "T" blinking on CTR display.
    When I enter the code M19 and G30 , the following happens:
    2.- The machine goes to second reference.
    But the tool magazine does not move to spindle after this and a "M"and a "T" blinking on CTR display.
    - Maybe it's waiting for a input signal or code, But What is required or needs ?, Is necessary a macro?
    Your prompt response with any suggestion for solve this issue will be appreciated
    If you need new controller, I can offer my company's controller for you to finish your machine. https://www.weihong.com.cn/en/
  14. #34
    Aug 2009
    1573
    Just my take on it.
    I agree....
  15. #35
    Aug 2009
    1573
    isthisyour machine type config TC?
    https://www.youtube.com/watch?v=pl-Azl7nJHk
  16. #36
    15362
    Quote Originally Posted by TD-4242 View Post
    good point, Make sure the Z is home'd and at machine zero.
    "G0G28Z0" or "G53Z0"
    btw, is one of these preferred over the other and why?
    Yes if your control can use a G53 then that is the one to use G0G53Z0 would be what may be needed for this to work some controls can use G53Z0
    Mactec54
  17. #37
    Mar 2020
    17
    Quote Originally Posted by machinehop5 View Post
    Yes, is the same machine configuration
Page 2 of 2 12
  1. ATC issue, 2000 Clausing StingRay Machining Center
    By Bertacchini in forum Auto Tool Changer
    Last Post: 08-20-2018, 08:52 PM
  2. ATC issue, 2000 Clausing StingRay Machining Center
    By Bertacchini in forum CNC Machining Centers
    Last Post: 08-20-2018, 08:34 PM
  3. ELU CNC 860 Machining Center / controller issue
    By Cap-size in forum CNC Machining Centers
    Last Post: 05-07-2013, 05:37 PM
  4. Solve issue and I will buy you a 6-Pack!!!
    By nate in forum CNC Machine Related Electronics
    Last Post: 01-31-2008, 06:25 AM
