Originally Posted by
Frankmali17
Sorry,
but I'm not on any Apps... like Whatsssap...
I wonder if you have the air pressure hoses connected to the spindle correctly...
How long was the machine operating correctly before HSD Spindle fail?... Why did the spindle Fail?
I am sure that reinstall the spindle the same before, the air pressure is ok, but i will revise tomorrow.
I wonder if the spindle in reinstalled correctly...
There are sensors and actuators.. .that send back signals to SYNTEC.. so that it can command-and-confirm the tool release is working.
I tried to track down some information based on my own SYNTEC 6MB controller...
in my error definitions I see the following information:
" MLC 78 (R44.13) = ATC failure alarm "
So when you try to execute the tool change... there is some failure of a sensor or actuator.. and SYNTEC sees the problem, and stops and doesn't allow the next steps.
This is probably impossible to fix over phone or over the internet...
DID you make sure the electrical and air connections are exactly the same as before removing the spindle?
