585,722 active members*
4,396 visitors online*
    Measuring Diameter
    Hi new to the forum and looking to solve a problem at work. I work in a machine shop on an automated line making yokes. If I can solve the problem we're having in a cost effective manner then I'll be entitled to a $1000 bonus. So we use Samung SL25 machines to make the yokes. Any time we change tools out we run a part, pull it out and check the diameter, We use a MAHR Federal 3 point v gauge to check the diameter. If the diameter is within spec which is +- .011 we resume production. If, however, the diameter is not within spec we scrap the part, offset the machine and resume operations. The problem is the diameter is 90% of the time out of spec and we have to scrap around 100 parts a week. Once the part is removed from the machine it can't be put back in and re-worked. So I was looking for a gauge that could measure diameter of the part while still in the machine. The thinking is after we change tools we intentionally offset the diameter to the small side, run the part, measure the part while still in the machine, offset the machine to bring the diameter back to spec and then run a macro that would just re-cut the diameter. What kind of instrument could do this for me?
    Apr 2004
    5734
    Re: Measuring Diameter
    I'm not sure what a "Samung SL25" is - is it a mill or a lathe? The spec doesn't seem too hard to achieve (if you're in inches, anyway). What accounts for the variation that's making you scrap so many parts?
    Andrew Werby
    Website
    It's a lathe. The diameter is in MM. The variation is due to changes in tooling or so I've been told. When you change an insert the slightest thing can set it off. It could be a sliver of metal under it or the seat, a slight variation from the manufacturer, you added coolant to the machine or the fact that the insert might have been tightened a little more or less than last time.
    Dec 2013
    5717
    Is it not possible to use a mic to measure in the machine? Maybe even a laser mic, but not sure if they make portable ones.
    Jim Dawson
    Sandy, Oregon, USA
    If I could use a MIC but it'd have to be portable and able to measure the part while in the chuck. That's the rub right there. If I take the part out I can't put it back in.
  1. When do you stop measuring rapids in IPM and start measuring in G?
    By slashmaster in forum Benchtop Machines
    Last Post: 07-08-2009, 10:42 PM
  2. Measuring screw thread diameter of acme threads
    By acidburn303 in forum Chucking and Measuring
    Last Post: 09-08-2008, 08:25 PM
  3. measuring a diameter by x & y point values
    By Doug Tyler in forum Calibration / Measurement
    Last Post: 01-05-2008, 12:18 AM
  4. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 09:51 PM
  5. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum Uncategorised MetalWorking Machines
    Last Post: 12-15-2007, 04:25 AM
