585,722 active members*
4,039 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Looking for help on build with smc4-4-16a16b
    Aug 2010
    7
    Angry Looking for help on build with smc4-4-16a16b
    Hi all I have a issue with an CNC controller I am trying to use
    https://www.nvcnc.net/smc4-4-16a16b.html
    Got via eBay and is driving a router table from same source.
    6040 Desktop CNC Router Engraver Milling Machine 3-Axis
    Issue I have is I can drive via the manual buttons but will not run though a DXF file
    Have had the DRO scrolling but no drive to the motors
    I am assuming I have to set some thing up first but not clear in the book
    Also has anyone using this controller that has a DXF that works in it so can test what is the issue?
    Thanks for any help John
    Jan 2006
    738
    Re: Looking for help on build with smc4-4-16a16b
    Hello, I noticed there have been no replies to your post, so here goes....
    You mentioned that it “will not run through a dxf file”
    This is understandable as a dxf file is a “drawing” file and not an “NC” (numerical control) file.
    In your case the NC file will consist of lines of “g code” which instruct your controller to run the machine.
    If you look on page 4 of your manual, you will see the start of the list of g codes.
    Here is the start of an example program:
    G90
    G20
    G49
    M3 S15000
    G0 X0.001 Y0.001 Z0.050
    G1 Z0.000 F13
    G1 X0.007 F50
    X4.999
    Y0.007
    Y0.026
    X4.993
    The first few lines set some parameters and are machine specific, there are many different flavors of g code just as there are many different machines. For example, your machine has 3 axis, is would not understand a command to rotate the A axis which does not exist.
    then there is one “M3 S15000” which turns the spindle on at 15,000 rpm
    Followed by “G0 X0.001 Y0.001 Z0.050” which tells the machine to move all 3 axis to a specific location.
    There are specific software programs to convert drawings, like dxf, to g code. They are called CAM software
    Some are very simple and cheap or free, others are more complex and not so cheap.
    I use V-carve pro from Vectric.
    After I have created or imported my drawing, I then tell V-carve to generate the tool path. Then I tell it to save the tool path at which point I have to select the specific machine I am saving it for so V-carve can generate the specific g code file for that specific machine.
    Do some searching for CAM software tutorials and you will get the idea.
    Steve
  1. Router home build Australia. Solid steel build
    By 80gus in forum DIY CNC Router Table Machines
    Last Post: 05-03-2020, 09:24 AM
  2. SMC4-4-16A16B and Geckodrive G540 ?
    By JustinP1 in forum Benchtop Machines
    Last Post: 06-21-2019, 02:50 AM
  3. CNC controller SMC4-4-16A16B
    By Beaker in forum Controller & Computer Solutions
    Last Post: 11-24-2017, 05:30 PM
