585,967 active members*
4,364 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Autodesk Post Processors > inventor/hsm post process issues
    Mar 2020
    hello, I am running a home built machine using USB cnc driver, I have used inventor to create my parts and my cam file.
    everything there seems correct all the tool paths and operations as I want. my issue seems to be when I submit to post process, this seems to shrink the size of the parts. taking total cut length from 1700 inches to 65 total inches. I'm not sure what it is that I am doing incorrectly to cause it to shrink.
    possible assumed reasons.
    wrong machine selected?
    miscommunication between inventor and hsm?
    scaling option selected in one or another?
    please help
    Thank you
    Sep 2017
    39
    Re: inventor/hsm post process issues
    What post processor are you selecting in Inventor? I too use Inventor for my home built CNC machine using both the UCNC ETH 300 controller and Mach 3 and select the Artsoft post processor Mach 3.
    Apr 2015
    8
    This is pretty close to the inch/millimeter conversion factor. Maybe its in the wrong units?
  1. Replies: 2
    Last Post: 07-01-2016, 02:32 AM
  2. Replies: 6
    Last Post: 11-04-2015, 05:48 PM
  3. Post for Anilam 6000M for inventor HSM
    By bmtrimp in forum Autodesk Post Processors
    Last Post: 03-30-2015, 02:34 PM
  4. Post Process
    By seapacer2 in forum Dolphin CAD/CAM
    Last Post: 03-02-2012, 01:20 AM
  5. Hypermill in Inventor issues
    By single phase in forum Hypermill
    Last Post: 06-11-2008, 02:50 AM
