585,712 active members*
4,302 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > How to get local variables to reset to null like fanuc does
Results 1 to 2 of 2
    Aug 2017
    3
    Hi all,
    I'm pretty familiar with programming macros for fanuc, getting more familiar with fagor macro programming, but I do have one issue, is there a way to get the local variables to reset to null, it just seems very dangerous to me for those to stay persistent, it makes it so I can't tell if those numbers were just entered, and there for I can use them, or if they were left there from some previous run.
    Examples
    I have a test program for G503
    this is all it does right now
    P101 = P3
    P102 = P11
    P103 = P5
    P104 = P19
    but right now there is no way for me to tell if you have entered any of the following
    G503
    G503 D3
    G503 D3 T2
    G503 L4
    G503 P1 T2 D2 L4
    As of right now, I don't see a way to know what was actually ran, and I wan't my macro to behave differently based on what variables are entered, or if no variables are entered, and I definitely do not want it to use what is currently in say p11 if there was no L specified.
    Aug 2017
    3
    Re: How to get local variables to reset to null like fanuc does
    I have figured it out.
    Looking at the G501 HSC mode subroutine that is supplied by Fagor, I saw that it also has optional values that you can put in, so I looked at that to see how they do it.
    V.C.PCALLP_{OPTIONAL PARAMETER} = 1 if you supplied a parameter, = 0 if you didn't
    if you put that in the call out, it will run what follows, if not it will go to the next step.
  1. please, help with local variables
    By deadlykitten in forum Okuma
    Last Post: 07-16-2023, 01:14 PM
  2. Local variables
    By underthetire in forum Haas Mills
    Last Post: 07-02-2012, 09:36 PM
  3. Local Variables?
    By TURNER in forum NCPlot G-Code editor / backplotter
    Last Post: 03-03-2008, 01:25 PM
  4. Local variables
    By jorgehrr in forum G-Code Programing
    Last Post: 02-19-2007, 10:03 PM
  5. G65 local variables help
    By FanukRC in forum G-Code Programing
    Last Post: 07-26-2006, 12:00 AM
