I need a close or similar replacement for a sound logic pc2 breakout board and dont seem to be having much luck in finding either a direct replacement or something real similar to it, could someone point me in the right direction?
Why does it have to be close to the Soundlogic board? That was a fairly standard breakout board; a currently-produced board won't be much different. If you're looking for something that runs from a parallel port, you'll be stuck with old and obsolete equipment. You'd do better to get a USB or ethernet adapter and bypass the parallel port altogether. Warp9 (makers of the Smoothstepper adapters) has a list of BOBs on their site: https://warp9td.com/index.php/bob-vendors
Because i dont want to reinvent the wheel and have to get in way over my head by trying to reconfigure the machine and change a bunch of settings that i don't understand, i just want the machine to be back up and running
There's only so many pins on a parallel connection.
I'd have thought most DB25 connector boards would suffice.
