585,898 active members*
5,077 visitors online*
IndustryArena Forum > CAM Software > CamWorks > is there a bug in ID turning allowances?
    Mar 2020
    Hello there my name is John and i would like to see if anyone else is having the same issue
    in ID turning at roughing when you give some allowance it gives it towards to the OD
    so i have tryied with a negative number and it works!
    BUT in the simulation it shows the piece with negative allowance! does anyone else have the same problem? is there any solution?
    Also i need one more advice
    when in roughing.... there is always one last pas extra like a "cleaning" pass that doesnt cut any material... how can i get rid of it?
    thank you all and sorry for my english
    Feb 2010
    69
    Re: is there a bug in ID turning allowances?
    Never had this issue with allowance, I put it in positive and it leave material (OD & ID)... for the rough cycle, you can set the final cut amount to zero and no cleanup will be generated
